So what's the difference between DDR, DDR2 and DDR3? Does it really improves performances as promised? Can the difference seen so obvious?
Few years ago, I bought PC with DDR1.. 500MB DDR1. It was running XP. Just within one year, DDR2 became common. I thought to myself, "I should have waited longer a bit."
Now, DDR2 is still common and we also getting nearer to DDR3...
My friend has Vista PC with 2GB DDR2 and it is sometimes slow and even lag. Sometimes when I use, I actually feel no difference in terms of speed or performance. It's just I think his PC can transfer files faster a bit than mine.
So the question is, if I have upgraded my PC from DDR1 to DDR2.. or if it were my choice.. would it be worth it?![]()
Thanks a lot for the explanation. I gather then that my memory isn't a problem at all not to mention a possible bottle neck. right? I just want to be really sure.
according to AMD's web site Athlon X3 and X4 both support DDR2, thank god for that.
http://www.amd.com/uk/products/desk...ocessor-model-numbers-feature-comparison.aspx
that's awesome to know, thanks! could I ask you about the hard drive? when you say it's a bottle neck do you mean I would need a better hard drive in general or just a solid state for the demanding operations that are important to me?
Wow, I guess 5 years from now systems will be monsters of performance, and I wonder how these changes will open doors for future leaps in computer tech. it's really interesting, thanks for explaining it!
