sysengrnz
I've got a question relating to resolution protocols:
1. When dealing with command prompt commands such as NSLOOKUP, PING etc, do these commands when utilized in this context operate at an adapter level but call functions up the OSI model to give the responses you receive?
or
2. When utilizing these commands in command prompt (at the application layer), does prompt work down the stack to call the functions which in turn give the responses you see? I.e..Destination Host Unreachable etc?
Will the "Netbios over TCP/IP" function, if I enable it on my network adapters, conflict with other methods of resolution such as LMHOST, WINS or DNS? Is there a priority in which these functions will operate if they're all enabled at the same time?
or
