Also...I'm guessing most people prefer amd over intel?
also do I need a sound card?
unless you have like $300 to spend on a SSD or dont plan on having a lot of files you wont replace the HDD with a SSD. you would still have a HDD for files you dont use as often but you would get something like a 60GB SSD for $100 or so and put your OS and a few games or other programs that you want to load fast.
and you are write about the wireless card. ive just had a hard time in the past so i stay away from it.
AMD is like G-D on this site. Really it just comes down to brand loyalty. AMD by its design as a budget CPU (the roots if the brand) runs hotter than intel. However that is nothing that an aftermarket CPU cooler can not fix.
do your god damned research. AMD has always been a "Budget" brand. The processing power has nothing to do with the price.
That is what is meant. They have always sold cheaper than intel. That is the meaning of budget, is it not??
You obviously didn't read farther down. AMD has always been cheaper for the same performance than intel. As per that, a budget unit. I was not saying that the desktop unit is a bad quality unit compared to Intel.The only reply I have for that is wrong or false. That is unless you think AMD and Intel just came out with processors 4 years ago. You are either very young or just started learning about computers.
Hell a FX-60/62 when first released were 1000 bucks.
If you want to argue the point with each model and over the years, go for it! When AMD had Intel beat clock for clock, Intel was a budget processor as far as price.
Your choice. We can talk models from the Intel Pentium I and AMD K-5. As far as price and performance clock for clock.
Welllll...what do you recommend? Decent brand please
On a Budget, AMD.
You will have better speed with just a ethernet card (the 1000 models. 10/100/1000) than you will ever get with a wireless card.
