In your price range you can go with either. A good Intel i5 or Phenom II X4/X6 setup could fit. In the 650/800 dollar range is really personal decision/toss up.
do your god damned research. AMD has always been a "Budget" brand. The processing power has nothing to do with the price.
That is what is meant. They have always sold cheaper than intel. That is the meaning of budget, is it not??
I understand you.
By BUDGET, I mean that they are more affordable. No one is arguing that point. I am not saying that their desktop product is sub-par to Intel. (I firmly believe based off of personal experience that the AMD notebook lineup is a horrible product. (( 6 CPU failures of 8 that I have owned or still own. 0 of 5 with intel)) )
I am calm. I just HATE AMD.
Yes, thats the processor in the spec.I meant just the wireless card, I thought my processor was this? http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851I
I thought wireless card would be something like.... crap I can't find it, but something that would be connected inside the tower?
What about this HDD? http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
also is this an all in one cd/dvd reader/writer? For some reason newegg keeps deleting
items out of my cart![]()
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
edit: also should I stick with the mid tower, or will I need a full tower for everything?
thus the AMD has a shorter operating life.
He said that he needs it to last for 5+ years. To me that says Intel.
+1This has went from ridiculous to hilarious.
Most of the time if you run head on into a cinder block wall, it hurts so bad you don't do it twice!
As also stated before, Multiple (6 total) CPU failures with AMD. I have never had an Intel CPU failure. That turns one quite quickly ya know.
still don't see why a moderator hasnt snipped our comments yet.
If you've had 6 cpu failures, its not the chip no matter who made it.As also stated before, Multiple (6 total) CPU failures with AMD. I have never had an Intel CPU failure. That turns one quite quickly ya know. still don't see why a moderator hasnt snipped our comments yet.
:good:For a wireless card, The OP would want probably need a PCI card or PCI-E card, right? I have no clues about CD/DVD drives. I just look for a cheap combo drive with decent speeds.
i think most newer mobo have the ethernet built in. the 89gtd does.You will have better speed with just a ethernet card (the 1000 models. 10/100/1000) than you will ever get with a wireless card.
Tower http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
HDD http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
All in one card reader http://www.newegg.com/Product/Product.aspx?Item=N82E16820816001
Ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820227559
CPU http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851
Fan http://www.newegg.com/Product/Product.aspx?Item=N82E16835103073
Video card/psu http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.553617
Motherboard/OS http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.552626
Cost me $1008.87...will be looking if it goes down by black friday
$987.87 with rebates
