is this SSD any good?
It is a good drive, yes, and no, you don't need that cable. All that you need is a SATA cable to connect the drive to your motherboard, and a SATA power connector from your power supply.
If your power supply has only molex connectors, which really if it is less than 5 years old, it should have SATA connectors, then you will need a molex - sata adapter, which is something like this:
http://www.scan.co.uk/products/seri...ta-(normal-psu-to-sata-sataii)-15cm-certified
why is that better its the same write read speed
Read and Write are near as makes no difference identical, yes, but the Vertex 2 is faster at IO operations. It doesn't make a whole lot of difference to be honest, but it is a better drive, on paper at least
