What should I buy?
Green Xenon
Hi:
I have 300 GB Maxtor DiamondMax HDD with Windows XP installed on it and I'd like to build new PC around it.
I'm looking for the least expensive PC system to buy and connect my HDD to. What should I purchase?
Thanks a bunch,
Green
P.S. More info about my HDD can be found below:
Cache: 16 MB
Model: 4D080H4
HDA: 24A
PCBA: 05A
Unique: 41A
Code: DAH017KO
Cylinders: 168383
Heads: 16
Sectors: 63
Extrenal Transfer Rate: Up to 100 MB/sec (Ultra ATA/100)
Buffer Size: 16 MB
Interface: ATA/EIDE up to 100 MB/sec data transfer rates
Spin speed: 7200 RPM
Average seek time: less than 10 ms
what will you use the computer for??
If the HDD is all you have, then you can build any computer around it. The Hard drive doesn't really affect the computer that much (Until you break it down to the seconds, and compare 5400 to 7200.) Just be sure that you get the drivers with all of your components.
You may have to do some lying to M$ to get it reactivated though.
