gamerwithoutrig
Is this: Corsair TX 750W PSU ATX 12V V2.2, 80 Plus, Standard. 4x 6+2-pin PCIe, 8x SATA, 140mm Vifte enough to power two GTX 470?
It should be. I've seen a few using that PSU in GTX 470 SLI systems, even with both cards and the processor (in this case an AMD Phenom II X6 1055t) overclocked.
My system:
Gigabyte GA-P55-USB3, Socket-1156
Intel Core™ i7 Quad Processor i7-870
Corsair Dominator DHX DDR3 1600MHz 8GB
EVGA GeForce GTX 470 1280MB PhysX CUDA (SLI in the future when I can pay for it)
WD Caviar® Black 1TB 3,5", SATA 6 Gb/s
Still think that it's enough?
Yes, it'll be fine, but the PSU will be pushed under full load.
And I'm thinking to get a ssd to.. Can it still handle it?
SSD's use negligable amounts of power, it should be fine
The antec calculator is outdated, BTW
Thanks for the double post.
Even an outdated PSU Calculator (not sure why you think it is)
will be more accurate than your guess "sure, it will be fine".
If you have something better, post it. If not, don't.
if your worried about "living on the edge" just get a 850W or so.
i cant, and do i need some extra fans?? im getting a haf x case, so i think it will fit some fans more than just 1 stock fan
Why not spend a little extra for some better cable management and airflow?
