MongrelNumber12
Poop
Delete
Delete
^ That^This
But i'd get the GTX470 if you want the NVIDIA brand with CUDA and PhysX aswell as the performance since it is better than the 6870 and cheaper than the one fastdude suggested on Newegg. But really both CUDA and PhysX isn't used that much.
Also the HD6870 draws less power and is cooler but with just a bit less performance.
Your decision, performance vs power drawing
^ That
Unless you really need the nVidia stuff (you don't need CUDA for gaming), then I'd go for the 6870.
470 beats 6870 in raw performance 60% of the time, but the slightly cheaper cost, less power usage, and good temps of the 6870 make it a much better buy IMO.
