Question - 1007322
[email protected] ]
Sent : 11/25/2010 03:59
Question : I'm running Award Modular BIOS v6.00PG
Answer - 1005367
Answer : During post does it indicate which version of the bios you are currently running?
Question - 1005367
[email protected] ]
Sent : 11/21/2010 02:39
Question : Yes printed on the board it says 8i845GV. F9 doesn't do anything in my BIOS
Answer - 1001775
Answer : Dear Customer
Please look at the model # which is printed on the board itself, is the model correct?
You can also go into bios and press F9 for system information and check the model # there as well
Question - 1001775
[email protected] ]
Sent : 11/13/2010 06:43
Question : I did download the F5 file, and used q flash in bios and it said "incorrect file size" I am sure this is is my motherboard, and I have tried do update it in bios, with q-flash, and @bios. They all say the same thing. "incorrect file size". The flash utility that downloaded with the update said "download the 4mb file" I don't think there is a 4mb file.
Answer - 999034
Please download the F5 off our website, use the q-flash utility to updating the bios
http://download.gigabyte.us/FileList/BIOS/motherboard_bios_8i845gv_f5.exe
Question - 999034
[email protected] ]
Sent : 11/7/2010 10:48
Question : The Bios update downloads for this motherboard don't seem to work. The in the flash update utility, it says "incorrect file size, download the 4mb bios file" it does the same thing when I try to update in bios.
Model Name : GA-8I845GV-C
M/B Rev : Not sure
BIOS Ver : v6.00
Serial No. :
Purchase Dealer :
VGA Brand : Integrated Model :
CPU Brand : Intel Model : P4 Speed : 2.4 ghz
Operation System : Win XP SP : 3
Memory Brand : Type :
Memory Size : Speed :
Power Supply : W
