1055t 2.8ghz with 8gb ram or 1090t 3.2ghz with 4gb ram?
Go1990
Just a quick question I would like to know as I'm going to have to choose one or the other for my computer and I would like to know which one would work well best for games, going to be using a GTS 250 1GB.
For gaming 4gb (2x2) is enough and the 1090t will be easier to overclock.
One more question
I'm going to use a case with 800W power supply, 120 mm fan and 80mm fan in it, If I do get a 1090t what should I overclock it to? The case is quite cheap but has a temperature reading on it so I can easily see if I'm screwing it up :) Also is the default heatsink good enough to overclock to 4GHZ :S
http://cgi.ebay.co.uk/MARS-R-BLACK-...ting_DesktopComponents_RL&hash=item19bd39340b
That case you posted is over priced and looks complete crap in terms of quality/airflow,and i take it your going to use the 800W power supply that comes with it?
I wouldnt.
Ebuyer do some good cases cheap,id buy a case from there and a seperate PSU....dont use an El cheapo one that comes with a cheap case,your asking for trouble :/
I wouldnt.
Lool, it's hard to find a decent case + decent PSU for under £70, or maybe im not looking right, a ATX mid tower case and maybe like 600W+ psu is all I need but I cant find decent and cheap ones.
But yeah, I'll research on ebuyer..
What are the full system specs you are looking at, what parts (if any) do you already have, what do you have left to get, and how much do you have to get all of that with?
Chances are, unless you are using 2 high end cards, 600W is overkill. And there is a reason you can't find good, xheap components - they don't exist. The term you get what you pay for is exactly right 99% of the time when it comes to computers
I have no parts yet, I'm looking to buy a 1090t 3.2GHZ, hoping to overclock it :) 4GB 1333 DDR3 RAM, a Nvidia GTS 250 1gb and since I was going for the 'el cheapo' case I thought with 800W it would be alright but I guess better quality is better :). And yeh, I found a case Coolermaster Elite 430 All Black With Elite 500W PSU for £62.98
http://www.ebuyer.com/product/235611
I have left to get mainly just the case and maybe a motherboard, I would like to get a good motherboard for under £50, asking for a lot probably but I havent really looked into any..
Just looked a bit into some cheap motherboards,and was wondering which of these motherboards in the best?
Asrock M3A UCC
http://www.ebuyer.com/product/231368
Gigabyte GA-770T-D3L
http://www.ebuyer.com/product/238971
ASUS M4A77TD
http://www.ebuyer.com/product/181964
Well, like I predicted, 600W is overkill. If the system is meant for gaming, it is also terribly unbalanced for gaming; your video card will hold you back and your CPU won't be used properly because most games don't use 4 cores
You are better off saving ~ £70 and getting a 955BE:
http://www.scan.co.uk/products/amd-...ion-sok-am3-32ghz-8mb-total-cache-125w-retail
Case: http://www.scan.co.uk/products/silverstone-precision-ps04b-all-black-mid-tower-case-w-o-psu
PSU: http://www.scan.co.uk/products/500w...ilder-series-80-eff-120mm-fan-single-rail-atx
Graphics: http://www.scan.co.uk/products/1gb-...700mhz-shader-1400mhz-336cores-dvi-d-sub-hdmi
Motherboard: http://www.scan.co.uk/products/msi-...r3-1800-2000(oc)-sata-iii-6gb-s-sata-raid-atx
Well, I want 6 cores because I use photoshop frequently, editing stuff, designing things for work etc ;) And I could work a lot quicker with this?
6 Cores doesn't really help all that much with PS, it will work flawlessly on 4. The only thing that will really push your CPU is large scale 2D rendering, graphic design isn't a bit problem at all for a quad core.
Is the system only going to be used for PS and similar software? Will there be any 3D rendering or gaming done at all?
Yeh I like to game in moderate amounts, not a very hardcore gamer but ye, wouldn't mind being able to play games like crysis etc which I wouldn't have been able to before :) Mainly PS and gaming :)
The parts that I listed would be better for that then than the one which you put together before.
What is the 4GB of memory that you were looking at getting?
1333mhz with no particular brand in mind, just the cheapest possible that will work :) I'm a cheapskate
Going for a GTS 450 1gb :) btw
CORSAIR XMS3 4GB (2 x 2GB) 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145218
Good enough?
This memory is faster than PC3 1066 RAM and it's the same price:
CORSAIR XMS3 4 gigabytes (2 x 2GB) 240-Pin DDR3 1600 (PC3 12800) Desktop Memory RAM - $55
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260
Same specs as that corsair for $5 less:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820313081
Or, wait for this to come back into stock, was $49.99 as well:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Or, $10 less than the corsair:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144461
If you can fit a GTX460 in your budget, like I posted, that would be a much, much better option.
For the links and prices everyone posted, they aren't any good. I assume, as you initially posted links to British websites and your budget is in £, you are in Britain. If so, Newegg don't ship outside of US, so you can't go by their prices, you will have to find the products you find in a British store, which is why I posted Scan, they give the best price the majority of the time, but check out Ebuyer/OcUK as well, they are sometimes better. If it works out overall cheaper with just 1 retailer though, go with that, shipping will be less
Sadly GTX 460 is just too much for me, and yeh, I live in britain so it's a shame, newegg certainly is a good site :) Maybe I'll go with a cheaper CPU and get one I'll see :)
This is taken from anandtech
