Twist86
So I just got my SSD and I was about to start transferring stuff off my Seagate and it started to make a wobbling high pitched sound. So before I RMA it I will use it till it either A. fails or B. my replacement gets here.
So I am fighting between these 3 drives atm.
1TB WD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136534&cm_re=1TB_HDD-_-22-136-534-_-Product
500GB WD
http://www.newegg.com/Product/Produ..._re=500GB_hdd_internal-_-22-136-320-_-Product
500GB Samsung
http://www.newegg.com/Product/Produ..._re=500GB_hdd_internal-_-22-152-181-_-Product
Now mind you I *might* use this strictly for storage (unpowered and used for backups) or I might use it as a secondary to the SSD.
Which one is best? I am not looking to spend much more but I want reliability again. I have had 4 seagate drives fail within a year of purchase and its getting old. My money is on the Black drive....I am kinda kicking myself as I had a chance to get the 1TB version for the same price during the BF/CM days.
However if I get the 1TB it will only be used till the replacement gets back and then used as a backup disk as I HATE multiple platters. My luck is the more platters the 3 months per platter sooner it breaks
1TB WD
500GB WD
500GB Samsung
