Fractal Design Define XL
gamerwithoutrig
Hello! I was thinking to buy ''Fractal Design Define XL'' and I wondered if it would fit ''Cooler Master Silent Pro M1000 1000W'', ''ASUS P7P55D Deluxe, Socket-1156'' and ''MSI GeForce GTX 480 1536MB PhysX CUDA SLI'' ?
edit: and ''Corsair A70 CPU Cooler''.
It definitely should, it's a full tower case. Make sure the store actually has the case in stock, it is nowhere to be seen even in Sweden where Fractal Design is from. The case has been delayed a couple of times this fall.
The shop will get 17 the 7. december. And when we're on it, will this go inside it?
Corsair XMS3 DDR3 1600MHz 4GB CL9
Intel Core™ i5 Quad Processor i5-760
Microsoft Windows 7 Ultimate EN
ASUS Maximus III GENE, Socket-1156
EVGA GeForce GTX 470 1280MB PhysX CUDA
Samsung SpinPoint F3 1TB
Corsair SSD Force Series 2,5" 80GB
Sony Optiarc DVD±RW burner AD-7263S
- And the PSU can handle two GTX 470, right?
Yes. The A70 is about the same size as the Noctua NH-D14, which fits inside the smaller Define R2 and R3 cases. Everything else should fit in just fine. The case is quite large as you can see in these videos.
[YT]U-u_KeRVvTQ[/YT]
[YT]nUZbDiwXYJo[/YT]
Yes. A good quality 750W PSU is enough for a dual GTX 470 setup, though an 850W PSU and up would be on the safe side. JonnyGuru has good in-depth reviews of PSUs, also of the one you chose.
The 1000W only costs 33$ more than the 850W version, so I'll go with the 1000W.
- And will all the parts fit together?
