Building a gaming Computer
Erich.k
Hi there I was hoping I could get some help with choosing what to get for a new gaming computer.
This is currently what I'm looking at
-Cooler Master HAF X Tower Case
-Intel Core™ i7 Processor 950 3.06GHz w/ 8MB Cache
Corsair Hydro Series H70 High-Performance CPU Cooler
-Asus Sabertooth X58 w/ Triple DDR3 1866, 7.1 Audio, Gigabit Lan, 1394, PCI-E, Quad CrossFireX / SLI
-Kingston HyperX 6GB PC3-12800 Triple Channel DDR3 Kit (3 x 2GB) w/ Intel XMP
-Asus ENGTX470 GeForce GTX 470 1280MB PCI-E w/ Dual DVI, HDMI
-Asus Xonar DX 7.1 PCI-E Soundcard
-Cooler Master Silent Pro M 850W Modular Power Supply
-LG Super-Multi 22x DVD Writer, SATA, Black (OEM)
-Seagate 1TB Barracuda 7200.12 SATA II w/ 32MB Cache
-Microsoft Windows 7 Professional x64 (64-bit)
The place im building it from is http://www.memoryexpress.com/SystemConfig/Default.aspx
Any help is greatly appriciated
Looks good, only things I'd change is replace the Barracuda with a WD Caviar Black or Samsung SpinPoint F3 1TB drive, switch from professional to home premium, and switch the GPU to a HD 6870, case is personal preference but the CM690 II cools almost as well as the HAF X, much cheaper, and looks better IMO. Excellent choice on the mobo.
hi there i was hoping i could get some help with choosing what to get for a new gaming computer.
This is currently what i'm looking at
-cooler master haf x tower case
-intel core™ i7 processor 950 3.06ghz w/ 8mb cache
corsair hydro series h70 high-performance cpu cooler
-asus sabertooth x58 w/ triple ddr3 1866, 7.1 audio, gigabit lan, 1394, pci-e, quad crossfirex / sli
-kingston hyperx 6gb pc3-12800 triple channel ddr3 kit (3 x 2gb) w/ intel xmp
-asus engtx470 geforce gtx 470 1280mb pci-e w/ dual dvi, hdmi
-asus xonar dx 7.1 pci-e soundcard
-cooler master silent pro m 850w modular power supply
-lg super-multi 22x dvd writer, sata, black (oem)
-seagate 1tb barracuda 7200.12 sata ii w/ 32mb cache
-microsoft windows 7 professional x64 (64-bit)
the place im building it from is http://www.memoryexpress.com/systemconfig/default.aspx
any help is greatly appriciated
.. Gtx 570.
Thanks for the quick replies and suggestions, have some quick questions do you the think the cooling system i chose (corsair h70) will be enough and also what would u recommend for thermal paste, one of my main concern's is keeping it cool.
Also with this build do you think I will be able to run arma2 and how long do you figure this system will last me without upgrading.
Once again thank you
The H70 comes with thermal paste pre-applied. It will be more than enough, it's a superb cooler. Yes, Arma II easily on high settings. I'd say you could last maybe 2 years without feeling the need to upgrade one of your core components (CPU, RAM, GPU, mobo)
Sound good, also i forgot to ask but would you happend to know when the 570 is out the only place i can find it somewhat close is ncix.
Thanks for all the help
So far its between the 6870 vs gtx570
so i switch everything but the case lol i like it too much
1 x Cooler Master - HAF X Tower Case $169.99
1 x Intel - Core™ i7 Processor 950 3.06GHz w/ 8MB Cache $289.99
1 x Corsair - Hydro Series H70 High-Performance CPU Cooler $99.99
1 x Asus - Sabertooth X58 w/ Triple DDR3 1866, 7.1 Audio, Gigabit Lan, 1394, PCI-E, Quad CrossFireX / SLI $214.99
1 x Kingston - HyperX 6GB PC3-12800 Triple Channel DDR3 Kit (3 x 2GB) w/ Intel XMP $109.99
1 x Western Digital - 1TB Caviar Black 7200rpm SATA III w/ 64MB Cache $85.99
1 x LG - Super-Multi 22x DVD Writer, SATA, Black (OEM) $19.99
1 x eVGA - GeForce GTX 580 1536MB GDDR5 PCI-E w/ Dual DVI, HDMI $549.99
1 x Asus - Xonar DX 7.1 PCI-E Soundcard $99.99
1 x Cooler Master - Silent Pro M 850W Modular Power Supply $149.99
1 x Assemble - Assemble Hardware + Load my O/S $70.00
1 x Microsoft - Windows 7 Home Premium x64 (64-bit) DVD - OEM $119.99
i went with the 580 because it was cheaper
Looks solid. Usually I wouldn't recommend Cooler Master PSUs but the silent Pro range are excellent units
