Gusterr
Alright, I've got all the major components in the case and now I'm working on the wiring.
I'm starting with the LEDs. I have four wires, which all have two holes aside from the green one that's split into two one-hole plugs.
-Red/White, labeled "H.D.D. LED"
-Orange/White, labeled "POWER SW"
-Blue/White, labeled "RESET SW"
-Green/White, split in two separate connectors. The green wire one is labeled "POW LED +" while the white wire one is labeled "POW LED -"
Actually, I think that answered my first question, which was: How do I tell which side of the connector is positive and which is negative? From the split green/white wires, I'm guessing white is also negatively charged on the other 3 wires.
Next, I've got these LED connectors on my MOBO:
-"Message/Power/Sleep LED", two prong
-"Power Switch", two prong
-"Speaker", four prong
-"Hard Drive Activity LED", two prong
-"Reset Switch", two prong
-"Chassis Intrusion Header", two prong
-"Power LED", three prong
I'm having trouble figuring out which LED cables go in which LED connectors. From the info I've given, any chance you guys can help?
I'm probably going to have more questions about wiring...
