Asus
Why does asus make it so difficult to download their drivers! They have no clear instructions on what to download, all they say is download this! But you download it and all it is, is a file???? I'm like what, why in the world would you do this! I just said screw it, my computer works fine so I'm not going to bother with complicated downloads! My computer is working fine without the drivers. So why should I bother.
They should take after gigabyte and when you click download, you get all the downloaded files you need, done automatically.
Tell me has anyone else had issues like this is Asus website and drivers?
Nope. I don't have this issue cause when I need them (I rarely do cause I don't use an ASUS board) I know what to download and what I'm doing.
Um I never had problems with gigabytes motherboards, and if you don't use an asus then y r you even posting, even people on asus websites are complaining about the way they do their drivers. To me it doesn't sound like you know what you are talking about, the reason I brought it up on here, was to see what the concensus was about asus websites? Cause obviously I'm not the only one, as their are a bunch of people complaining about it. With gigabyte its straight forward. With Asus it's not, maybe b4 you comment you should do ur own research b4 posting! Also I want to know how many certifications do you have? (0)
Just because I don't use an ASUS board doesn't mean I've never used their drivers site. I had an Eee and got drivers for that off their site no problem. I've also worked on custom machines that had ASUS boards in them and I had to get drivers for the off their site. I've never had an issue with it before. Sure their servers are a little slow, but that's the only problem I've ever had.
EDIT: And yes, you are correct. I don't have any certifications. So what? It doesn't mean I don't know what I'm talking about and doing.
+1^
+2^
I dont have any trouble either.
= 3
