A good video card for Starcraft 2
iamevanwang
Hi everyone,
I want to buy a video card for my Lenovo IdeaCentre K320 desktop computer since I believe there are no video cards in there. I am about to get a copy of starcraft 2 but I am afraid that's it's going to lag since call of duty black ops lag a bit when I'm playing it. I included a picture of the part of the motherboard that I think is where you put the video card. If it's not where you put the video card, please tell me where it is. Also, I don't know anything about what video card or socket... or what I should do because the retailer didn't mention it. Please leave me a suggestion and thank you for commenting!! :)
dont need to be 3D or anything, just make sure it's cheap and starcraft 2 play well:)
My budget is around 100~200
Okay, you've got a PCI-E Slot. That's good. But what powersupply do you have? Brand and model please.
@linkin First of all, Thank you for commenting
i don't know what power supply I have because I didn't put it together but at the back of the tower there's a switch that can switch voltage supply(I guessed, according to the manual) and the numbers are 115 and 230, I'm currently at 115. Also, I included a picture of my power supply... take a look and maybe find out. thanx!! :)
Looks like it's a 250W PSU. And I'm also guessing it's an HP (guessing from how the mobo looks)
If you want a good dedicated card to play SCII you'll have to upgrade your PSU cause it probably doesn't have a 6-pin power cable and it's too weak to power anything.
