Hello
Motherboard: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290502512803&ssPageName=STRK:MESINDXX:IT
Asus Crosshair IV Extreme Socket AM3/ AMD 890FX/
Processor: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170478734371&ssPageName=STRK:MESINDXX:IT
AMD Phenom II X6 Processor 1090T CPU 3.2 GHz AM3 Black
RAM/Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231380
G.SKILL Trident+ Turbulence II 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-8GBTDD
Video Card: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290513082317&ssPageName=STRK:MESINDXX:IT
PowerColor ATI Radeon HD6970 2GB DDR5 2DVI/HDMI/2x
Hard Disk: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150496795279&ssPageName=STRK:MESINDXX:IT
1.5TB 1500GB [64MB Cache] 7200RPM SATA2 Hard Drive
Optical Drive: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200505377576&ssPageName=STRK:MESINDXX:IT
LITE-ON 24X BURNER IHAS424-98 SATA DVD RW LIGHTSCRIBE
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817153132
Thermaltake TPG-750M Toughpower Grand GOLD 750W ATX 12V V2.3 / EPS 12V 2.92 SLI Certified CrossFire Certified 80 PLUS GOLD Certified Modular Active PFC Power Supply
Tower Case: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230563379312&ssPageName=STRK:MESINDXX:IT
NZXT G921RB Mid Tower Black/RED Computer Case
I need somebody who can tell me if some of these components are compatible
Only components I am not sure if they are compatible is ATX case and EATX Motherboard 12in. x 10.6 in.
Ram for Intel P55 chipset only?
Does Power Supply have all the Molex connectors the PC will need?
Thanks.
Thanks.
