DOSBox 0.74 : Can it run in full screen
dominicb
Hi all
I've downloaded and installed DOSBox 0.74 to play an old DOS computer game and it works fine. Just one problem : it plays in a small window in the middle of my 22" monitor. I don't want it to use the full monitor screen as all the graphics would look chunky, but it would be nice if I could enlarge the window.
Does anyone know of or could recommend a similar DOS emulator, the window of which would be enlargeable?
Thanks
DominicB
Just go into the config file of DOSBox in notepad and set "fullscreen=false" to "fullscreen=true"
Might also want to set the resolution to something a bit higher so it doesn't stretch the image too bad.
Thanks for that voyagerfan99. It does work exactly as described, but ...
Is there a flag to set it to so that I can set the size by dragging the bottom left hand corner of the window?
Thanks
DominicB
Thanks
DominicB
Nope. Gotta manually type the resolution in the config.
