ultimatedesk
Hey everyone,
Decided a few weeks ago to start building my own custom computer desk / enclosure and I thought some of you would be interested in checking it out, so here goes
I'd like to firstly thank Crucial, Kingston and Danger Den for sponsoring this project and for helping make it a reality:
The 1st draft of the Ultimate Computer Desk.
I wanted the desk to be capable of having 2 integrated desktop systems. 1 for high-powered gaming, and the other, a low-powered system with lots of hard-drive space that will be on 24/7 for sharing media across the network and playing videos locally.
It needs to be quiet, have dust control, have manual fan control, and it also needs to look great in an office - sorry ahead of time to all you bling lovers!
I used Google Sketchup for all of my drafts.
I started first by sketching on paper how I would like the components to be laid out, and then started working on the left-hand module.
After determining the minimum width, I started to build up the left-hand module, taking into consideration that I would be using 3/4" plywood for the construction.
I then decided that the air intake will be on the same board that the motherboard will lie, air will come from the bottom. It will be covered with a furnace air filter material that should eliminate most of the dust, and also provide good air circulation.
Next up was to add some to-scale components. A big thanks to B@gy, who created the model for the Noctua NH-U12P CPU Heatsink, as well as the Noctua fans, Alexander who created the model for the Asus Ares video card, Nightsoul who created the model of the Western Digital Hard-Drives, and Fubar East for the very nice power supply model. Your talent saved me a lot of time when it came to placing the items to scale.
Another view, from the back
I then took the same requirements and applied them to the right-hand module. This will be the "server-type" system. I also wanted to add drawers to this particular module, so this is what I came up with. It has the same air-intake system, which will be covered by a furnace air filter.
And, finally, putting it all together, I figured 2 monitors is a reasonable thing these days. In the upper left, there will be the DVD drive, plus power and fan controls for the gaming rig. There is a glass cover over the gaming rig that can be removed to perform upgrades and maintenance.
And a picture of the back - the boxes aren't exactly what they'll turn out as - they are for cable management, ideally I will setup little boxes so you will see almost NO cables in the back. They will have some foam stuffed in the top to keep dust out of the boxes as well.
And that's it for this post! The 1st draft! I'll have to ponder on it for a little while to make sure everything is A-OK for building, and determine how much lumber I'll need.
As always, comments, feedback and ideas are ALWAYS WELCOME! This is going to be a long build, I figure it'll take me a couple months at least, and that's not including some of the custom electronic trickery I'm going to have to learn!
