Wireless Internet is "Not Connected"
mm320
Ok this all started with the first problem. The sound on my computer kept stuttering. I made a thread about that and someone suggested to remove the driver for my Network Adapter and re-install it. So Did that. I then re-installed the driver for the Network Adapter. But when i click the Wireless "thing" in the toolbar it says Not Connected. I ran Troubleshooting and it said the problem was "Windows could not automatically detect this network's proxy setting." So i went to Network Connections (where it shows my wireless adapters) and I had 3 things there. 1. My bluetooth (Not Connected). 2. Broadband Connection (Disconnected) and 3. Wireless network connection (Not Connected). It recognizes my adapter its just "not connected". I just got the new Tablet and it frustrating me. Please Help me asap!
I guess no one has ever told you to never buy stuff from china just because its cheaper. There are a lot of people getting ripped off by buying stuff from there. My advice to you would be to return both tablets since they both have the same issue with the sound and now yours doesn't connect. If it didn't come with a warranty, you are out of luck.
Wow, that's helpful. Thanks for nothing, Tea Cup.
In response to the actual issue, there are quite a few steps you can take to troubleshoot this. First, which device are we going to look at? The tablet or the desktop? What Operating System is that device using? Also, you described a "Broadband Connection" listed in your Network Connections; am I to assume you typically have this device connected with an Ethernet cable and have to double-click that icon and hit "Connect" before you can use the internet regularly? Finally, what type of wireless router are you using?
I'm not bashing him.... But if you would look at his other posts, you would see that they bought 2 of these tablets from china and they are both having the same sound issue he described in his other thread.
And evidentely, you haven't been keeping up with the times...
I never said you were bashing him... I said you were about as helpful as tits on a fish. Thanks again for nothing, Captain Hindsight. The next time I have an issue, I'll be sure to create a thread where a "Super Moderator" will undoubtedly wag his finger at me, as opposed to actually trying to help. Cheers.
:eek:
Sorry, just doing a little research here on why he got banned, I see I have to go no further :P
Surprised he didn't get banned that very day.
Yep, he's gone. He was bashing another user besides me so something had to be done.
