Hi,
I'm trying to build a computer for ~350.00 USD that would be capable of playing World of Warcraft as well as some other basic things. I'm not worried about playing on max graphics settings, just looking to get it as lag free as possible for the price.
About a month ago a user named "Drenlin" posted up a build in response to a post here - http://www.computerforum.com/186854-first-complete-computer-build.html
I liked the build, was around the price point I'm looking at but unfortunately the combo deals have expired.
I've made my own build, I was hoping I could get some feedback.
-Is everything compatible?
-Would I need to buy any other hardware/cables?
-If anyone could find cheaper/better components that would be appreciated.
RAM -
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) - 50.00 USD
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Case + DVD -
LIAN LI Lancool PC-K58W Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower + LITE-ON 24X DVD Writer Black SATA - 86.00 USD
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.579097
Power supply + Hard drive -
COOLER MASTER Elite 460 RS-460-PSAR-J3 460W ATX12V V2.31 + Seagate Barracuda 7200.11 1.5TB 7200 RPM SATA 3.0Gb/s - 100.00 USD
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.578311
Motherboard + CPU -
GIGABYTE GA-MA770T-UD3 AM3 AMD 770 ATX AMD + AMD Phenom II X2 545 Callisto 3.0GHz Socket AM3 80W Dual-Core Processor OEM - 130.00 USD
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.581279
Total: 366.00 USD + 8.00 Shipping
I'm not sure if the combo deals are worth it, or if I'd be better off buying separate items to save money.
Thanks.
RAM -
Case + DVD -
Motherboard + CPU -
Thanks.
