Hard drive sizes are getting up to 2,000 gigabytes (2 terabytes) and larger. I would recommend getting an external enclosure for a Serial ATA hard drive that way you could use it as an external or convert it to an internal hard drive. Take a look at the following:
Rosewill RX35-AT-SU BLK Aluminum 3.5" Black USB 2.0 External Enclosure - $24
http://www.newegg.com/Product/Produ...rue&Keywords=(keywords)&Page=1#scrollFullInfo
SAMSUNG Spinpoint F3 HD103SJ 1 Terabyte 7200 RPM 32MB Cache Serial ATA Hard Drive - $70
http://www.newegg.com/Product/Produ...e=samsung_spinpoint_f3-_-22-152-185-_-Product
sandisk are the best usb drive, the highest ive seen is 32gb
Are you talking usb hard drives? Or flash drives? I got a 2TB hard drive which is something in proximity of 2,048 GB. (I think. I can never remember.) It was on sale for 79.99, but you can probably get a 1TB for about that price now.
Or, you can get a Flash Drive that is 16 GB for about 50 bucks on amazon.
I don't care which I just want something I can use for large older personal computer/public file transfers.
Well how big are you talking here? Or how much and of what are you trying to store?
Yeah your gonna need an external hard drive if your looking at 250-500gb. its its just for file transfer speed isnt really and issue so just make sure its USB plug in and your set
...or eSATA if your PC supports it, but this is much rarer, so its not going to work in as many situations as USB would. (but it's capable of much faster transfer speeds then USB 2.0)
How much do you want to spend?
No. "2.5 hard drives in enclosures are essentially identical to normal external hard drives (most "external hard drives" are just laptop hard drives with a case and USB logic) - they need no power adapters. You're probably thinking of bigger "3.5 enclosures for desktop hard drives - those things do need more power than USB can supply.if you use hard drive enclosure, don't you have to have a power adapter?
