raoul_1101
Greetings, Computer Forum!
I am looking into building my first HTPC! I would like to go with a small (very small) form factor. If everyone seems opposed, maybe I'll get something bigger (micro or mini ATX).
First off, looking at what was available from newegg for ITX and mini DTX- this is the motherboard I was looking into:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128457
I do like Gigabyte as a brand, but if anyone would like to suggest something better, I'm open to ideas.
Paired with this, I had an i3 picked out to go along (a little overkill, probably?).
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115221
I would probably put in 2GB of Ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104182
For a video card, I decided for an GeForce 9800:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133308
I would add a TV Tuner card as well, with these two in mind:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116015
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116037
The first one comes with a remote- however, my case also come with a remote. I was wondering- would I be able to use my windows remote that comes with the case and not use the TV tuner remote at all? I would like to consolidate remotes, I already have too many. Also, between those cards, what are the big differences?
In addition to everything above, I would put in a single 1TB HDD, and this wireless card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16839121008
What are your guys' thoughts on this build?
(This build comes out to $668)
