garrypeace
AMD or Intel. This will be the first component I am buying. Are there any CPUs that you can recommend for a budget of $160 / £100?
Thanks.
Thanks.
if you can spare an extra $20 get the i5 2300,it will leave the 955 in the dust.even tho its not a K version it will still OC to 4.0+. http://www.newegg.com/Product/Product.aspx?Item=N82E16819115076
Doesn't the non-K series have a very hard time overclocking via the bus? I've heard any more than a 5mhz increase on it is pretty much impossible. Still really fast CPU though, go for it if you can afford it.
To the OP... Do you even plan on OC'ing since this is the first time you are buying components? Also, are you buying for a current motherboard or for a new one. It's kind of hard to help you when people don't know what you're going for. Silly people throwing out random CPUs.![]()
AMD or Intel.This will be the first component I am buying. Are there any CPUs that you can recommend for a budget of $160 / £100?
well since he said this will be hes FIRST component and hes asking which CPU is the best at hes price point AMD or Intel we all assume that this is a new built,useless stated other wise.
Ugh... His question is like if he was asking 'what tires do you recommend for my car'?
Bottom line is you don't know what he/she is planning on doing, so how can you best help them by throwing out random information. Do they plan on overclocking? Do they plan on gaming, multitasking, every day use? Depending on their answer you can get a processor that fits their need and could save them money and they could use it else where for more RAM, bigger monitor, etc...
How can you help someone if you don't know what to help them with....![]()
CPU Stock Turbo | OC + Turbo (P67 only)
4c 3c 2c 1c | 4c 3c 2c 1c
i5-2300 2.8 2.9 3.0 3.0 3.1 | 3.3 3.4 3.4 3.5
i5-2400 3.1 3.2 3.3 3.3 3.4 | 3.6 3.7 3.7 3.8
i5-2500 3.3 3.4 3.5 3.6 3.7 | 3.8 3.9 4.0 4.1
i5-2500K 3.3 3.4 3.5 3.6 3.7 | 5.7 5.7 5.7 5.7
i7-2600 3.4 3.5 3.6 3.7 3.8 | 3.9 4.0 4.1 4.2
i7-2600K 3.4 3.5 3.6 3.7 3.8 | 5.7 5.7 5.7 5.7
its just common sense bro.
garrypeace - What kind of computer do you want to build and how much money are you looking to spend? And as far as which to buy first, usually what I like to do and was recommended to me was buy a motherboard first that will 'future-proof' you so you don't have to try to keep up with technology.
A pretty powerful one. Spending about $1600 over the course of the next few months. I'll probably find all components and put the specs up here for review.
Thank you.
