Thanks for the tip but unfortunately I still cannot connect to my server through Firefox. IE and Chrome work just fine. Also my Google search engine kept on getting redirected by iMesh to other search sites. I went in regedit and took out imesh but I don't know yet if it stopped the redirection because I cannot get to the internet with my Firefox. Any ideas? I love my Firefox. Chrome is my second choice but this really pisses me off. WHY is my question? Any ideas would be welcome to get my server to connect with Firefox. Thanks.
You are infected, please do the following and post the logs for me.
Please download Malwarebytes' Anti-Malware from
here or
here and save it to your desktop.
- Double-click mbam-setup.exe and follow the prompts to install the program.
- At the end, be sure a checkmark is placed next to
- Update Malwarebytes' Anti-Malware
- and Launch Malwarebytes' Anti-Malware
- then click Finish.
- If an update is found, it will download and install the latest version. Please keep updating until it says you have the latest version.
- Once the program has loaded, select Perform quick scan, then click Scan.
- When the scan is complete, click OK, then Show Results to view the results.
- Be sure that everything is checked, and click Remove Selected.
- A log will be saved automatically which you can access by clicking on the Logs tab within Malwarebytes' Anti-Malware
If for some reason Malwarebytes will not install or run please download and run
Rkill.scr,
Rkill.exe, or
Rkill.com but
DO NOT reboot the system and then try installing or running Malwarebytes. If Rkill (which is a black box) appears and then disappears right away or you get a message saying rkill is infected, keep trying to run rkill until it over powers the infection and temporarily kills it. Once a log appears on the screen, you can try running malwarebytes or downloading other programs.
Download the HijackThis installer from
here.
Run the installer and choose
Install, indicating that you accept the licence agreement. The installer will place a shortcut on your desktop and launch HijackThis.
Click
Do a system scan and save a logfile
