If you want to compare your computer temperatures to what it suppose to be, I like this place: http://www.cpu-world.com/CPUs/CPU.html
Probably the best, easy to use and free is SIW....
Download System Information for Windows (SIW free version)
No installation required.
After it scans your computer, navigate to Hardware>Sensors and you'll see all info from there.
I have an AMD Phenom II X4 955 3.2GHz. Speccy tells me it is running at 37 degrees Celsius. Is this normal?
Surely, BIOS is the best, but since this is not life/death situation, if you want a quick look and you can live with couple of degrees difference, I see nothing wrong with those readings.
In most cases, we simply want to know, how far/close our CPU temp is from a critical temp.
If max temp is listed at, say 60C, it doesn't make a difference, if I see 19C, or 22C.
Far enough from 60C.
But your processor isn't running at room temperature either, I can pretty much guarantee that. I'd be pretty impressed if you were running under 30*c, and even that is unlikely, so really its a difference of about 10*c not 2-3. I'm not so petty that I'd make remarks over such a slight difference, but if the temp readings are off by any significant margin, then it may be enough to think you're fine when your CPU is too hot, or that an overclock has more headroom for voltage when it really doesn't have any wiggle room. It may not make much difference at idle, but if under load you're running that same CPU at 55*c then you're over 60*c, not below it. I'm in the same boat with my 1055T and I found my temps were off by a good 10*c. My computer would come out of sleep mode overnight and coretemp would read 13*c. As much as I loved seeing my idle temps below 20*c I knew I should probably fix it haha.
Play a game or download one of many CPU stress testers and watch your temps. It may not heat up as much as you think.
