New here and have my build specs.
XLR8
Hi all. This will be my first complete build,all though I have did much with them. I have a build layed out and would like some feed back on it. The only thing I need (unless you all see somthing I'm missing) is a PSU.
A few remarks about what and why I have this build.
Gaming.internet. Not running dual GPUs,OC yes to around 4ghz,no micro MB and have a sound blaster Titanium sound card I will use.
PARTS
sandy bridge i5 2500k
ASRock P67 Extreme4 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Produ...Deals-_-na-_-na&AID=10521304&PID=3463938&SID=
G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL
case>NZXT Phantom PHAN-001WT White Steel / Plastic ATX Full Tower Computer Case
>EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Hard drive and OS
http://www.newegg.com/Product/Combo...Deals-_-na-_-na&AID=10521304&PID=3463938&SID=
ASUS Black 24X DVD+R 8X
COOLER MASTER Hyper 212 Plus
There are a couple of fans,thermal paste I will also get.
If at all posible the PSU could be under $100'
Thanks
Thanks for the help.That PSU looks good.This is new territory for me on PSUs. Is the 800 watts for future proofing,or is it the lowest watts that can be used.
future proofing, but with 850 watt i dont think you can overclock if your getting a new gtx 570
Heavy overclocks on everything with two 570's could stress an 850W quite a bit, though I think that PSU might handle it. With a single 570, you're perfectly fine.
Thanks again for all your help. I am only going to run 1 gpu. From what I have read the 570 not overclocked is a beast. The CPU will be overclocked but by what I have read a mini OC compared to the Hz some are OX the K. As this is my first complete build I am still learning.
Now just because in anal and like things to look pretty, but still ahve good build quality if I were you I'd be getting this because, you getting the white Phantom, and this PSU is white as well lol :) dont get it wrong though its still a great PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817116012&cm_re=nzxt-_-17-116-012-_-Product
Yeah I have seen this psu in a white phanton case.Looks good.
I'm still bouncing back and forth on the color of the case. My fist coice was the red one.Than I saw the white one and looked pretty cool. But I have not ruled out the black one yet.
