zombine210
BAM!
this is my gaming rig :gun:
SslagleZ28
The shortcuts your talking about is called a Dock. There are several different ones you can get. I use Both ObjectDock, and RocketDock. RocketDock is the one at the bottom. ObjectDock isn't showed in the screen shot because I have it set to only pop up when I put my mouse over it. The rest is RainMeter, which at first may seem complicated, but isn't to hard. It takes time to learn how everything works, and to get it how you want it. I've probably got 10 hours into customizing mine. Thats including spending hours looking for themes, and icons I like though, which I've very picky about.
ObjectDock: http://www.stardock.com/products/objectdock/
ObjectDock addons: http://www.wincustomize.com/explore/objectdock
RocketDock: http://rocketdock.com/
RocketDock addons: http://rocketdock.com/addons/all/popular
RainMeter: http://rainmeter.net/RainCMS/
RainMeter addons: http://customize.org/rainmeter
Help, and instructions:
OD:http://forums.wincustomize.com/82930
RD:http://rocketdock.com/Help/English/
RM:http://rainmeter.net/RainCMS/?q=Rainmeter101
very cool and thank you, i think i'll stat playing around with it this weekend
memory
I just started messing with Docks.
Instead of changing the icons all together, is there a way to give them a different look, for example, a rusty look?
Shane
Super Moderator
Ubuntu Studio X64.
Im shocked at how fast Linux runs compared to windows,I was running this in a Virtual machine with 1GB ram,1 cpu core and 12mb vid memory and it just flys,alot faster than Windows is on my SSD and my full system :D
I really hope one day Linux takes off and goes somewhat mainstream,I cant see why not i mean it has ALOT of potential.
salvage-this
^ I have been meaning to try Ubuntu Studio for a while now. How do you like it?
I agree with you that I wish that Linux would take off. It has been amazing me since the day I started using it. Unfortunately I thing most people are too afraid of change to give it a try.
Shane
Super Moderator
I like it alot,Its not all that much diffrent from the standard Ubuntu install really,software center was missing so i had to install that within Terminal,but nothing that a quick google search couldnt help me with.
I think thats what puts alot of people off from using Linux is those commands,but thats the only time ive actually had to use it.
Using this today just really shows how slow windows actually is in comparison. :D
salvage-this
Synaptic is good for downloading the extra plugins that you would normally get through the terminal. I use it all the time to grab extra packages.
SslagleZ28
Just started playing with docks, and going to start with themeing as well, but for the time being
SslagleZ28
^ Looks good dude, I like the Dock theme. Which dock is that? I used to have that same wallpaper lol. If your looking for some wallpapers this is personally my favorite site http://wall.alphacoders.com/wallpaper_categories.php
ty sir... yeah you have me hooked now lol, this is actually fun messin aroudn with the dock, and icons and such.... i used the rocketdock like you said and its the Fireblade tribal skin. Looks pretty cool... and ill def check out that website, i change my desktop liek 4 times a week :D
Fatback
Yeah it really fun to mess with, so many different things you can do with it.
Heres mine right now, I'll probably keep it like this for a little while.
SslagleZ28
now what do you use to create where your itunes is, and how you have your disks, and signal strength?
Fatback
