Help with build £900
eddzzz
Right I have do idea where to start on a build as this is my first. I want to use this website for my components: www.aria.co.uk Can someone make me a very rough outline of a tower. I do not need a monitor, mouse etc... Any help greatly apreciated.
Eddie
Thanks for the speedy reply. I do not require a OS. My usage will be heavy and for high end gaming running the latest games. Rather than the SSD what would you upgrade for another £125? Thanks,
Eddie
+1
Mobo - ASUS P8P67 Pro
Video card - 6950 - such that you can flash it to 6970 yourself.
For extra £75 (instead of SSD), I'd stick with standard P8P67 and get GTX570 OC - it's same speed as HD6970, HD6950 unlocked is not quite as fast as proper HD6970.
I'd pick the SSD over the faster GPU, but since you're underbudget, why not have both? :D
EDIT: Or perhaps have 8GB of RAM.
Are you going to SLi/ Crossfire in future?
If yes, you won't want your second video run at x4. That's why go for 'Pro'. if not, you can get slight cheaper PSU at 550 - 650w
Because of Intels Sandybridge thing. I dont fully understand it but theres a problem what would you recommend differently rather than the sandybridge cpu??
I suggest you wait until end of the month for their fixing up.
you could get core i7 950 with X58, but sandybridge still better choice
