demonikal
My HP Pavilion dv2000 (Windows Vista) laptop is having issues with the LCD monitor. Upon pressing the power key, the monitor looks as it should all the way until just before and sometimes right after the desktop appears. Then the screen goes black. Also, strangely, when I hooked up my external Acer 22" Widescreen LCD monitor to the VGA port on the laptop and configured the resolutions settings, the screen will re-appear on the laptop monitor and then yet again disappear to black.
I troubleshooted the specific problem via HP support on their website, but the last thing that might be the problem is also a problem. It involves pressing <F10> repeatedly on startup. Goes into BIOS and I'm suppose to choose "Test hard drive for errors" or "Test hard drive." I did that, but since the LCD external monitor isn't recognized in BIOS, I have to depend on the laptop monitor. I clicked Enter for the test, it says will take ~82 minutes [for the test] and then of course the screen goes black, so I can't even determine if the hard drive is the problem even if I waited 82 minutes cuz of the black screen.
If this sounds like a somewhat common problem and likely is something having to do with the laptop monitor and not the hard drive, please let me know what I have to do...likely what I have to replace to fix the monitor and if it involves taking the whole thing apart [since I don't see any screws anywhere on the hinges holding the monitor on].
Thanks!
Thanks!
