Troncoso
Okay so on new egg these CPU's range from $124 to $179. A quick inspection shows that the only real difference between each is their initial clock speed the lowest starts at 2.8ghz and goes up to 3.5ghz.
Is this the only difference? Their cache is all the same. There are use 45 nm technology.
The only difference I could find was that the cheapest was 95w instead of 125w like the rest. But doesn't that mean it uses less power? Which is a good thing?
So my final question: Could I just get the 925, OC to around 3.5ghz and have basically a 970? Or does black edition mean something?
