1080p video playing : minimum requirements?
could anyone verify if this could do it?
AMD Athlon 64 X2 2.2Ghz Processor (Socket AM2)
Geforce 6150 Video Card
1.5 Gb DDR2 Memory
New 160GB 7200RPM Hard Drive
Multi DVD Burner
RCA, S-Video, VGA and DVI Video Outputs
HD Optical Audio Output
USB and Firewire Ports
3-in-1 Card Reader (CF, MS, SD)
Quiet Fan
1.5 Gb DDR2 Memory
Multi DVD Burner
Quiet Fan
Guess it could, but not the best for it?
Stealthy, that rig will *not* run 1080p well, if at all. Biggest problem is your video card. Next would be the RAM, then the CPU. Also, if you plan on running this on a TV, expect to put some serious cash into this rig, as your needing a new CPU will mean a new mobo. New GPU means probably new PSU. And RAM.
