aznhypnotix
What do you guys think about Comcast Cable Modems w/ Netgear Routers? Any issues or does it work great?
You gotta be careful when purchasing own modem from 3rd party vendor like amazon or other because they may be EOL (end of life) status. If you purchase your own router you would have to get tech support directly from the manufacturer otherwise you can get free support for using a Comcast issued router.
Sometimes powercycling or reseting the router will help with connectivity issues. You may reset your Network Name (SSID) & PassPhrase (network login password) if you reset the router by sticking a pin in the hole located behind the router which means you have to login to the router manager website to re-secure your network connection.
