hi!ur laptop is equipped with a wirless lan card.so just enable the wireless lancard on, on both laptops and turn on file and printer sharing on at the network and sharing center.after enabling the wirless lancard,u can set up the adhock network on one laptop by following the wizard,enter ur preferd network name and wizard will guide through the remaing phase.u can then sarc forthe same network automatically on the other laptop,via mnaging wirless networks,connect to a network.note the wpa key u used in setting up the network and enter it after connecting to the network for authentication and complete the connection.you don't need to purchase any router except if u have more than 2 laptops.all d best.my laptop is Dell XPS L501. It has wireless modem. I dont know how to apply true setting. I want to sharing my files between their via wireless. I think wireless router is not necessary.
I made wireless connection
I made a home group and I joined with 2 laptops
I can find other computer but I receive error.
this is error picture:
How can I be sure?
