Hi, Building a new computer. Can someone recommend a power supply? Hoping to find some thing 650/800W and is quiet. And would like to stay under $100.00
Thank you, Mark
Seasonic power supplies are usually quiet, though you might have trouble finding one un $100. How quiet are the rest of your computer components?
Thank for the reply. I am just looking at parts now for a new build. But I do want everything to be quiet. This computer will be in the living room.
What part of Ma. Are you from?
I wouldn't trust a fanless PSU in a warm climate... but thats just me.
I ran a fanless PSU in an unventilated garage for two years in central California. Temps in the summer would exceed 100 for weeks at a time and the temp in the garage would go well over 125.
It worked just fine. Worked better than the freezer that was in that some garage...
The basic trick is, get the largest fan PSU you can fit that is of high quality.
The fan removes heat. Heat is waste. Inefficiency causes waste, thus a high efficiency PSU generates less heat for the same load. And costs less too.
I would recommend a 140mm fan, as this is about as big as you can go in a ATX PSU. The bigger the quieter, all things being equal.
If you want the rest to be silent, you need to water cool.
yeah, but your efficiency would have plummeted! Especially with 115VAC. 140mm actively cooled PSU's are the way to go. They are near on silent.
Now you are just looking for excuses not to go fanless. The question was "what's the quietest' not "what's almost quiet but efficient".
You could look for a fanless PSU, and use large fans in the case to promote airflow over the heatsinks...
This fanless idea is alittle on the lame side. He said he wanted a quiet power supply in the 650 to 800W range for 100 bucks.
A quality fanless 400w power supply runs 100 bucks. This idea of getting a fanless power supply and getting more case fans to keep it cool. Am I missing something here?
A good quality power supply with 120 or 140 fan I think would be just fine.
