Hi Guys well first of all My name is Paul,I am from California, and I am really excited to be joining your community, so here is where I stand....
My old computer (Not worth mentioning LoL) is just not doing it for me. I had build computers on the past but I stop for a while. After my tax returns I am looking to build me a Monster Gaming Desktop that can take everything I put in front of it. I use my computer a lot its on almost 24/7 with a lot of traffic passing through,and a few TB used already
I play a lot of games:FFIV,WOW,COV,SC2 and to be honest I am tired of playing on the lowest resolution
........ PLEASE help me out!!!
$2000 is what I have to work with and I had being looking around a little and this is what I am thinking on buying
CPU: Intel Core i7 950 3.06GHz 8M L3 Cache (Overclock)
http://www.newegg.com/Product/Produ...211&cm_re=intel_i7_950-_-19-115-211-_-Product
CPU cooler: ? Water cooling maybe
Case: Rosewill THOR Gaming ATX Full Tower Computer Case or NZXT Phantom PHAN-001WT White Steel / Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147094
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
MOBO: ASUS P6X58D Premium
http://www.newegg.com/Product/Produ...re=ASUS_P6X58D_Premium-_-13-131-614-_-Product
RAM: 12GB kit (4GBx3), 240-pin DIMM, DDR3 PC3-10600 memory module
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=56F7169BA5CA7304
HDD:Western Digital 2 TB Caviar Black SATA 7200 RPM 64 MB Cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136456
Video card: SAPPHIRE 100312SR Radeon HD 6950 2GB 256-bit GDDR5
http://www.newegg.com/Product/Produ...4&cm_re=2gb_video_card-_-14-102-914-_-Product
Audio card: ?
Power Supply: Corsair CMPSU-750TX 750-Watt TX Series 80 Plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Optical drive: Pioneer Internal Blu-ray Disc/DVD/CD Writer BDR-206
http://www.amazon.com/gp/product/B0046K062C/ref=ord_cart_shr?ie=UTF8&m=ATVPDKIKX0DER
OS: Windows 7 64 bit
I will be using the following monitors Sony BRAVIA EX 500 Series 40-Inch LCD TV, and ViewSonic VX2250WM-LED 22-Inch.
Feel Free to Make any suggestions on anything that may not be compatible or would save me some money and its around the same performance.
Thank you for taking the time to read this
Audio card: ?
