bsmith6470
Hey all! Which of the PSU's would be the better buy? They are $10 apart in price. I have read good things about both.
The Silverstone Strider Gold 1200W:
http://www.silverstonetek.com/products/p_contents.php?pno=ST1200-G&area=
Corsair Gold AX1200W:
http://www.corsair.com/power-supplies/modular-psus/professional-series-gold-2/ax1200.html
These will be powering an i7 2600K, 2 Gigabyte GTX 570 factory OC in SLI on an Asus P8P67 Deluxe MOBO fitted with 8 GB 1.5V PC 14900 G.Skill Ripjaws RAM. Windows 7 64-bit.
It will have a Coolermaster V6GT cooler, about 6 HDD (4 of which will be a RAID10), and a standard compliment of case fans. The case will most likely be the Coolermaster HAF X nVidia Edition.
Very little OC'ing to the CPU will be done, if any. I may play with GPU OC, but nothing permanent. I do not OC RAM. Ever.
I want solid, stable power with ample headroom. Two builds ago I had an Antec True Power, it died after 18 months. The present build has an Enermax. Fine PSU, but I am recently getting PSU fan RPM fluctuations. i.e., under-speed warnings on startup. Been running it for 5 years.
I want to go to a single 12v rail on this build.
