winchcomputer
hi guys, im from australia, and i work in a panelshop. About a year ago, we were broken into, and uninsured, so lost everything.
As we had no security measures in place, there was basically nothing we could do.
I've installed an alarm, and a computer with a 4 input capture card (OLD Pico2000 software, cheap card) and originally, was running windows xp
i had a heap of issues in regards to networking, and a stop error here and there and after thinking about it, i realised that the card, and the software, is dated 2000, before windows xp
due to not having a copy of Windows 2000, and never liking it anyway, i reverted back to Windows 98.
Deleted all partitions, formatted the SATA hard drive as fat32, and then mapped the Sata Channels as legacy IDE in the bios, along with the Primary IDE channel, which the DVD burner is using.
Initially i had a problem with the bios not storing settings, such as the legacy config, and could not boot into windows 98, due to it having 6 channels, rather than the expected 4.
after replacing the cmos battery, and it having no effect, i realised it was a matter of changing the bios jumper to "config", and then back to "normal" when i was done, yay intel for making it hard
through changing the battery, the time was reset.
after getting windows 98 to boot, and being happy with everything, apart from a few devices missing drivers (i dont need onboard sound anyway), i installed the Pico2000 software, and card
everything working well, so it would seem, and so i left in on overnight.
this morning i come back, and i have a Fatal Exception error in "VXD VTD (01)"
To my knowledge, that means there was an exception with the virtual timing device in windows, but i have no idea how this works.
The system is a P4, with 2x512 mb ram, and an intel board.
The ram was in "dual channel" mode, as in stick 1 in slot 1 of channel a, stick 2 in slot 1 of channel b.
The time was incorrect, and i wasnt sure how 98 would handle dual channel ram.
After setting the time, and pulling out ram 2, and putting it in slot 2 of channel a for "Single channel" mode, i boot the computer, and everything looks normal.
No exceptions YET
what im wondering, is has anyone on Windows 98 come across this error before? and if so, did you find it was a System clock issue, a ram issue, or a software issue?
i have NOT checked the ram, and have not ruled it out as a possibility, but am exploring other avenues first, as the error said VTD.\
could the virtual timing device crash because it came across a bad sector in the ram? or could it be as simple as the fact that the time hadnt been set, and the system date was prior to the software being developed?
BTW this system is not used for anything other that recording camera input, and networking via encrypted VPN to view said video, so im not worried about security when putting it online, but as of yet, i havent even installed the LAN drivers
any help would be appreciated
With windows 7, vista, and xp, Windows 98 is more or less gone, but not forgotten.
after returning to it after all these years, im amazed at the response, and ease of use, but puzzled by the errors
also, i have hyperthreading enabled for the cpu, havent diabled it because i know in the past i have run 98 systems with hyperthreading for years, without issues, and i really dont understand how it works anyway
thanks
No exceptions YET
thanks
