dellxps420
banned
well i was just wondering how you guys clean your computer's inside and out as these do get really dusty quick
Inside of the computer i use a hairdryer on cold and have had no problems at
all.
most common is a can of compressed air, although they can cause damage if used to close, you can buy products for your screen and case but if always used a lightly damped cloth and had no probs, depending on the finish of your case if it is high gloss you can polish it to a nice shine
vacuum cleaners are the best. You don't ahve to worry about canned air damaging anything as long as you don't shake the can and you use it in short bursts. Though, they loose their pressure pretty quickly and it gets frustrating. If your vacuum has a blow feature thats the way to go.
No one else uses an industrial vacuum + industrial air compressor (with humidity filters and drop legs mind you)? I guess that makes my comp the cleanest in the west.
I dont have a industrial vac, but I just use my compressor (humidity filter and just a plain filter) with the PSI drop gauge set to 10 PSI. never had a problem with it.
