Upgrading my PC
baseball2k27
My PC is kind of outdated by a few years, it's not horrible but it's not good enough to keep up with modern gaming. So I've decided to attempt to upgrade my computer. First off I've got an old ATI Raedon HD 2400 pro for a graphics card, a Intel Core 2 Duo CPU E4500 @ 2.20 GHZ and only 288 GB HD.
Any suggestions or any more information needed to know what I can upgrade with/my computer is compatible with?
I'm trying to get a RIG that can run ARMA II and battlefield 3 when they come out. Doesn't have to be on high graphics, just capable of playing them with decent graphics on like normal.
Would you be able to give us some more information?
Is it a custom-built machine, and if so, what motherboard and power supply are in it?
If it's an off the shelf OEM unit (HP, Dell, eMachines, etc...), what is the model number?
What is your budget like for upgrades?
From that information, I will be able to give you recommendations for stable hardware upgrades.
Regards,
-Chris
Okay, that's a start. The Antec 300 is a really nice case to work with, I've built several machines using them and they are great.
I take it you are using this thing mostly for gaming?
I would recommend doing an AMD/ATI platform. You can really get some excellent performance on a budget that way at the moment.
I have some errands to run, and and awards ceremony to attend tonight, but I'll put together a build for you when I get back.
Good luck, and talk to you soon
-Chris
P.S. Are you located in the states?
-Chris
yes I am.
Okay, so here's what I've come up with for you:
Chassis: Antec Three Hundred Illusion
Power Supply: Antec TruePower New TP-650 650W
Motherboard: GIGABYTE GA-880GMA-UD2H
Processor: AMD Phenom II X4 840 Propus 3.2GHz
Memory: G.SKILL Ripjaws Series 4GB (2 x 2GB) DDR3 1333
Video Card: SAPPHIRE Vapor-X Radeon HD 5770
Hard Drive: HITACHI Deskstar 7K1000.C 1TB 7200 RPM 32MB Cache
Optical Drive: LG SATA DVD±RW SuperMulti Drive
All the parts above are from newegg.com.
Total: $586.92 + ~$10-$20 Shipping - $20 Mail-in Rebate on the Video Card
This rig will stomp the crap out of ARMA II and Battlefield 3 :P.
Good luck and let me know what you think.
-Chris
At the rate I'm saving I should have the money by June So it'l probably be cheaper correct? So at that time should I get a better video card?
Components prices are bound to shift a bit in the next few months, and there will likely be some nice new deals available. Shop around when you have about $600 to spend and you'll find some deals you can't pass up.
The HD 5770 is a great card, it's in Tier-6 of the Tom's Hardware Hierarchy. It will definitely stomp all games that are out and will conceivably come out in the next couple years. If you did want an upgrade from that I would go with a 6870 or 6970.
if you get a good drive it will last. Western Digital blacks and Samsung F4's are the longest lasting drives on the market.
The Antec 300 is a nightmare in cable management.
Something like the NZXT Beta EVO and Cooler Master HAF 912 are better cases.
Motherboard. Get a ASRock 870 EXTREME3 or ASUS M4A87T or ASUS M4A87TD/USB3
Video card. Get a 6850 instead of a 5770.
Harddrive. Get a Western Digital Black/Samsung F3 or Seagate 7200.12
Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
so
PowerSupply:http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
MotherBoard:http://www.newegg.com/Product/Produ...re=ASRock_870_EXTREME3-_-13-157-198-_-Product
VideoCard: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150505
CPU:http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
Chassis:http://www.newegg.com/Product/Product.aspx?Item=N82E16811146059&Tpk=NZXT Beta EVO
HardDrive:http://www.newegg.com/Product/Produ...52185&cm_re=Samsung_f3-_-22-152-185-_-Product
CD Drive:http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231275
Fan:http://www.newegg.com/Product/Product.aspx?Item=N82E16811998121
Good?
About 690 dollars plus shipping and handling without rebates.
