hello.pls help with bluescreen problem
mrbals
hello!pls i need assistance on how to resolve a bluescreen problem i ve been experiencing for weeks.i ve browsed online n diffrent sites on how to correct the problem but was to no avail.here is d report of the error message below.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.256.6
Locale ID: 16393
Additional information about the problem:
BCCode: 44
BCP1: 8822C008
BCP2: 00001D0C
BCP3: 00000000
BCP4: 00000000
OS Version: 6_0_6001
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\Mini022411-01.dmp
C:\Users\sony\AppData\Local\Temp\WER-176983-0.sysdata.xml
C:\Users\sony\AppData\Local\Temp\WERBAE5.tmp.version.txt
intel core 2 duo [email protected]
win vista buisnees 32 bit.3gb RAM,250gb hdd
There are a few reasons why to get a blue screen. Have you recently installed anything, I have seen blue screens due to low end software that does not run well inside the OS (i.e Vista). But if all you get is a blue screen and you are unable to get into the OS there might have been some damage done to the OS and I am hoping in your case you have the Vista disc. If you do then put it in and boot from disc and use the repair tool to try and fix it and if that doesnt work then reformat the whole thing.
If you have no Windows disc I would recommend a Linux Os, we do not worry about blue screens.
