gmcjetpilot
I have two DELL Optiplex computers, both same case and P4 CPU's.
I know switching the secondary hard drive (the one with out the OS) is a no brainer, but can you switch the main 'C:' drive between computers?
One has 1.8 Ghz CPU and 512 Mb ram, two hard drives and PCI cards for video, TV and Wi-Fi. I want to down grade this one.
The other is a 2.8 Ghz CPU, 1024 Mb ram, one hard drive and no other PCI cards. I want to upgrade this one with all the hard drive and accessories above.
I want to take both hard drives out of one, with the PCI hardware cards and put into the other. Not sure if there is a BIOS issue?
Can I just do this? What issues will I run into. I can see doing it the old fashion way, and just removing the items from one computer and reloading all the drivers and configuration on the second computer. I was hoping to just swap the two with out going through the nitty gritty. Then the computer down grade, the slower one will just have to be cleaned up. This is what I am trying to avoid.The other is a 2.8 Ghz CPU, 1024 Mb ram, one hard drive and no other PCI cards. I want to upgrade this one with all the hard drive and accessories above.
