Good Build !?
MrWain
Need to buy a new comp,
budget of £800 or just over by a £10 or £15
i am using it for programs such as
photoshop,
illustrator,
3ds max,
maya,
avid media composer,
premiere pro,
after effects,
and just mainly graphical production,
maybe the odd online game but nothing with the hd capabilities of WoW just simple crappy stuff which is addctive xD
and well do you tink this is a good build .. i think as a start it will do upgrade on ram shortly after due to more funds and possible little upgrades but let me no please :)
AMD IIX6 1090T
Asus m4a78lt-m
4gb ram
1 gb ati radeon hd 5770
1tb hard drive
2x cd driver
600w psu
trippler cooper cpu cooler
24" 1928x1080 monitor
and then alll the little extras such as lan and wirless card soundcard xD nothing special in them just onboard crap for now and like wireless mouse and keyboard come with you no all the usual shite :P
£795
so good deal !?
i am willing to build this computer and purchasing the components from external sources if this will be cheaper i do have the correct knowledge in buiding a computer etc so that wouldnt be a problem just anyone no of any good UK companies to purchase components from :D
Hold the presses! If your primary activity is Adobe Photoshop and Premiere, you need to switch to the Sandy Bridge CPUs (which of course also means changing mobo and maybe RAM). Take a look at this article:
http://www.tomshardware.com/reviews/sandy-bridge-core-i7-2600k-core-i5-2500k,2833-15.html
And switching to an nVidia graphics card with CUDA to speed up those two applications:
http://www.tomshardware.com/reviews/adobe-cs5-cuda-64-bit,2770-8.html
Maya I think also makes good use of CUDA - but I am not as familiar with that.
Take a look at those articles and let us know what you think. You can also go to the Adobe site and read more about CUDA - and of course the nVidia site has more info.
ok definitely looks good to get a sandy bridge and a CUDA, and yes i am willing to wait up to another 2 months to purchase this just any idea how this will effect the price in my budget compared to the parts, will i still get a pretty decent kick off computer that can be upgraded for the budget set !? :D
thanks for the reply to :D
ok ive had a look around taking in mind the sandy bridges from the post above and am now wondering which from the two would be the best build ?!
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
XFX ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card with FREE AVP, Stalker, CODMW2 Games & 3D Mark 2011
Patriot Viper 2 Sector 7 6GB (3x2GB) PC3-12800C8 1600MHz Triple Channel Memory Kit
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard
OCZ StealthXStream 2 700W Power Supply
Coolermaster HAF 912 Plus Case - Black
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM
that or the original build i posted
this one comes in at
£786 included p&p
you will need to get a 1155 board, not AM3.
And your boards onboard sound processor should be fine for what you need.
took that into consideration
is this any better !?
Asus P8H67M-EVO Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge)
OCZ StealthXStream 2 600W Power Supply
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £738.88
just a word of advice, If you install that triple channel kit on a 1155 board, you will be running in single channel mode. The 1155 is dual channel and 4 slot. You will need to look for a 8 GB kit to take advantage of dual channel (4 x 2gb or 2 x 4gb) or a 4GB kit (2 x 2gb).
alight ill make the changes hehe, im not very good at this am i xD
cheers for the advice :)
