This is the first round.. after researching all afternoon on this site and some other ones, I put this together on newegg. It's been several years since I've built a system, but please be harsh. I will be using this primarily for software development, which can be very IO intensive. This is the reason for the 10k storage disks and the separate OS disk. I will be using the two 600 gigs in RAID 1.
A big sticking point for me is the bottom vs top mounted PSU case. After reading so much rhetoric, I came to the conclusion that letting the PSU work in cooler air (at the bottom) and using its fan for itself instead of everything else would be better for its lifespan. The case comes with three other fans and room for more. I'm not terribly worried about picking up dust. It's going to pick up dust anyway.
On that note, I haven't picked out a PSU yet, but was going for around 650W, modular, active, with multiple 12V rails. Are the rails a big advantage?
AMD Phenom II X4 965
G.SKILL 4GB 240 pin DDR3 1333 (x2 for 8GB)
OCZ Vertex 2 2.5" 80GB SATA II MLC SSD (OS disk)
Western Digital VelociRaptor 600GB 10000 RPM SATA 6.0Gb/s 3.5" (storage disks in RAID 1)
GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX
COOLER MASTER RC-692-KKN2 CM690 II Advanced Black Steel ATX Mid Tower
Thanks!
Thanks!
