System Build :3
sir peter666
Hey Everyone,
I'm wishing to build a new desktop that can play latest games, and normal stuff. I have listed all the parts the interest me below. I'm posting because I'm not sure if they are all compatible with each other. If possible I like to swap out some stuff to make it cheaper or better. My budget is $1,200.
Case: http://canadacomputers.com/product_info.php?cPath=569_6_112&item_id=023780 $89.99
Power Supply: http://canadacomputers.com/product_info.php?cPath=569_33_442&item_id=028790 $49.99
Optical Drive: http://canadacomputers.com/product_info.php?cPath=3_61&item_id=029356 $24.99
Motherboard: http://canadacomputers.com/product_info.php?cPath=569_26_340&item_id=029369 $142.99
Processor: http://canadacomputers.com/product_info.php?cPath=569_4_64&item_id=028512 $97.99
Processor Cooler: http://canadacomputers.com/product_info.php?cPath=8_135&item_id=036688 $69.99
Memory: http://canadacomputers.com/product_info.php?cPath=569_24_311_312_611&item_id=032949 $109.99
Hard Drive: http://canadacomputers.com/product_info.php?cPath=569_15_179&item_id=031401 $109.99
Operating System: http://canadacomputers.com/product_info.php?cPath=39_530&item_id=026489 $149.99
=$845.91
Thanks,
~Peter F
if your wanting to play all the latest games then your going to need a dedicated graphics card. look to spend at least $175 for a decent one, and i would look into a better power supply unit, maybe a corsair, pc power and cooling, or antec true.
I'm a little confused.
What exactly is the budget?
When do you plan to purchase?
Do rebates count?
Do you need just the tower and it's components, and Windows?
Do you plan to add a second GPU down the road as an upgrade? Or just get a bigger card when that time comes?
