mihir
Earlier I had a Thermaltake Toughpower 650W.It blew up so I switched to a seasonic 750W.The PSU I had earlier might not be better in quality from the current PSU but the cable management was better since I can choose which power cables to connect.In this all cables are pre-connected.
I also installed my TRUE 120 rev C today.
My question is I was thinking about painting the inside of my case matte black.I wanted to ask what kind of paint should I buy.Spray Paint or something else and also I wanted to know how to paint the case should I dissassemble the entire case like the HDD rack and also the 5.25 bay Rack or just paint it as it is with the racks installed.And any extra advice on the painting thing would be a help.And should I wash the case first before painting it and how should I dry?I dont know I am very confused and this is the first time I am painting something.
Since cooler master haf 932 has a lot of holes which get filled with a lot of dust.How should i clean it I have used a hair dryer but it didnt work nor did tissues nor wet tissues.
