[BUILDING PC] Will it work?
jd132
YA..everything should fit/work fine. BTW...your HDD link goes to your video card... ;)
As for the case..it depends on how much money you wanna spend... Heres a few:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146025
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
I have the three hundred, and its a great case... :) But the 900 is better...
The 900,300, and the CoolerMaster, have the best AIRFLOW. Also ALL of those cases have two(2)fans premounted... :) Good Luck and if you have any more q's just ask...thats what were here for... ;)
Hackfyr16
I've a pretty big CPU cooler and video card, so are you 100% that there's space for ALL my parts :), I just don't want to spend money on something I can't use :)
Thank you very much, you've been a big help! - Would kiss you if i could *lol*
"A 6950 GPU will not fit in this case" (feedback)
Hackfyr16
Motherboard (180$): http://www.newegg.com/Product/Product.aspx?Item=N82E16813130574&Tpk=MSI P67A-GD65 B3
Video card: (360$): http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593
HDD (90$): http://www.newegg.com/Product/Produ...na&AID=10521304&PID=4169961&SID=1k5mn59dgg43a
CPU (225$): http://www.newegg.com/Product/Produ...9115072&cm_re=i5_2500k-_-19-115-072-_-Product
CPU cooler (90$): http://www.newegg.com/Product/Produ...-na&AID=10521304&PID=4169961&SID=64c19kop77o7
RAM (130$): http://www.newegg.com/Product/Product.aspx?Item=N82E16820233142
Power Supply (120$): http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012&cm_re=17-139-_-17-139-012-_-Product
Case: (100$) http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
changed video card/power S. and found a case.
- Will you check that the video card/power S will work/fit.
- THe case is big enough
- My Cpu cooler will work, someone told me, that some of the models won't work with some modo, and i cant find anything about it. would be a big help!
It will be the last post, wont disturb you anymore ;)
cratecomps
Ram
You may want to up the speed on the ram, the motherboard shown supports 1800,2000, or 2200. I think you had DDR 1600. It may still work, but the faster the memory the better. Its gonna be nice, good luck!!
Hackfyr16
Speed up on the ram?, I'm not sure what you mean and the ram I've picked out won't be able to work with me motherboard? because my RAM is 1600? and my mobo doesn't support that?
- if yes, could you find some RAM that my mobo would work together with
Peace
Hackfyr16
Okay now!
I'm ready to purchase after those few questings!
That my new video card/power S will work/fit, (VC: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593 , PW: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012&cm_re=corsair-_-17-139-012-_-Product
That the case I've chosen is big enough http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
- will my CPU cooler work with the modo, someone told me, that some of the models won't work with some modo, and i cant find anything about it.
