Was bored, so decided to make a little chart of some common processors since the time of the Pentium 4. I used the cpu benchmarks found on Tom's hardware to do this, and gave the processors a Ghz speed based off the Intel Pentium 4 3.00Ghz processor. (score of 491) I simply divided each processor's score by 491 to tell me how many times faster it was than the P4 3.0Ghz base. Then I took that number and multiplied it by 3 to find its "Ghz."
Now obviously, the Ghz speeds of current processors is completely correct, however much the architecture and supporting components have changed. Modern-day cpus do not run at 50 or 60 Ghz. This is just a simple chart where I translated the processor scores into Ghz, based on the Pentium 4. Many of these processors will score differently in relation to each other, depending on which specific benchmark you run - in part due to how many cores it has and how many cores a specific program or game can utilize and in what way. Obviously, there are simply way too many variables at play to consider the below chart to be at all viable. The only real value of the below chart, when considering the Ghz speeds, would be the processors' relation to each other concerning this one benchmark. However, I figured it would be a decent rough indicator of each processor's power, albeit with many exceptions and conditional factors, such as multiple cores or usage.
Note: I favor AMD cpus as I'm much more familiar with them than Intel. I am well aware that Intel completely dominates the high-end market right now, and have obviously left out many processors. The processors I have picked are merely ones I am more familiar with and/or are interested in. My selections are in no way an implication of anything.
Intel Core i7 980X --------------------64.86 Ghz
AMD Phenom II X6 1100T-------------38.70 Ghz
Intel Core i7 870---------------------37.38 Ghz
AMD Phenom II X6 1090T-------------37.08 Ghz
Intel Core i7 930---------------------35.67 Ghz
AMD Phenom II X6 1075T-------------35.64 Ghz
Intel Core i7 920---------------------34.02 Ghz
AMD Phenom II X6 1055T-------------31.77 Ghz
Intel Core2 Quad Q9650--------------28.23 Ghz
Intel Core i5 760---------------------27.99 Ghz
AMD Phenom II X4 975---------------27.42 Ghz
AMD Phenom II X4 970---------------27.21 Ghz
Intel Core2 Quad Q9550--------------26.73 Ghz
AMD Phenom II X4 965---------------26.16 Ghz
Intel Core2 Quad Q9450--------------24.63 Ghz
AMD Phenom II X4 955---------------24.12 Ghz
AMD Phenom II X4 840---------------23.31 Ghz
AMD Athlon II X4 645----------------22.59 Ghz
Intel Core2 Quad Q8400--------------22.50 Ghz
AMD Phenom II X4 940---------------22.50 Ghz
AMD Phenom II X4 945---------------22.05 Ghz
Intel Core2 Quad Q9300--------------21.90 Ghz
AMD Athlon II X4 640----------------21.27 Ghz
AMD Athlon II X4 630----------------19.86 Ghz
AMD Athlon II X4 620----------------18.24 Ghz
Intel Core2 Quad Q6600--------------18.21 Ghz
AMD Phenom 9850 Quad-Core --------18.06 Ghz
Intel Core i3 530---------------------16.74 Ghz
AMD Phenom 9650 Quad-Core--------16.20 Ghz
AMD Phenom II X3 720---------------15.90 Ghz
Intel Core2 Duo E8400---------------13.77 Ghz
AMD Phenom II X2 550---------------11.55 Ghz
AMD Athlon 64 X2 Dual Core 6400+---10.89 Ghz
AMD Athlon 64 X2 Dual Core 6000+---10.05 Ghz
AMD Athlon 64 X2 Dual Core 5600+---9.39 Ghz
Intel Core2 Duo E6600---------------9.21 Ghz
AMD Athlon 64 X2 Dual Core 5200+---8.70 Ghz
AMD Athlon 64 X2 Dual Core 5000+---8.31 Ghz
AMD Athlon 64 X2 Dual Core 4800+---8.04 Ghz
AMD Athlon 64 X2 Dual Core 4600+---7.74 Ghz
AMD Athlon 64 X2 Dual Core 4400+---7.29 Ghz
AMD Athlon 64 X2 Dual Core 4200+---7.05 Ghz
AMD Athlon 64 X2 Dual Core 4000+---6.72 Ghz
AMD Athlon 64 X2 Dual Core 3800+---6.42 Ghz
Intel Pentium D 3.40GHz-------------5.67 Ghz
Intel Pentium D 3.00GHz-------------4.95 Ghz
AMD Athlon 64 FX-57----------------4.62 Ghz
Intel Pentium D 2.80GHz-------------4.53 Ghz
AMD Athlon 64 4000+----------------3.99 Ghz
AMD Athlon 64 3700+----------------3.63 Ghz
AMD Athlon 64 3500+----------------3.45 Ghz
Intel Pentium 4 3.40GHz --------------3.36 Ghz
AMD Athlon 64 3200+----------------3.24 Ghz
Intel Pentium 4 3.20GHz --------------3.21 Ghz
AMD Athlon 64 3000+----------------3.00 Ghz
Intel Pentium 4 3.00GHz --------------3.00 Ghz
We've come a long way.
