Rampage Formula Auto Restart..
NickAiman
Hello...
I've problem with my Asus Rampage Formula MOtherboard...
When I turn on my pc and it will automatic restart before boot windows..
I don't know what happen..
Could someone help me...I really2 need the help..
Could be bad hard drive or any other bad hardware. Remove anything not needed to boot and see if it boots into windows. Remove all usb devices, any addon pci cards. If it still won't boot up then you need to get the hard drive checked.
Was it working fine and then it just rebooted when you turned it on? The hard drive isn't from another system is it?
John, do you think a virus could do this? Maybe a virus that got into the BIOS?
It's a slim possibility that the bios has been infected, I'm guessing its more bad hardware related. I've seen this so many times, its not funny.
If you say hardware
which one hardware which involved in this problem?
How 2 i know it?
How for me know it troubled?
How 2 test the hardware?
Remove all non essential hardware - that is NOTHING except smallest amount of ram, boot hard drive and key board.
Reset the bios (remove the battery for 1 minute)
Boot into the the bios
Set to default settings
Enter into safe mode with networking (tap F8 on start up)
Post results.
I'm really2 sorry because late to reply..
I can't remove the graphic card that's because my rampage don't have
onboard graphic.
So..
I try to format windows and flash the bios with the new one.
Reset the bios (remove the battery for 1 minute) and Set to default settings like u said
My motherboard so far so good..
If my motherboard receives any problem. Hope you can help me again.
Thanks for your help..:):good:
2 days ago it's so far so good but just now..
I got again problem on my PC..
When I turn on my pc and it will automatic restart even in cmos setting..
I try to remove the hard disk and enter CMOS setting but it still restarts..
My PC Spec is Rampage Formula motherboard + Intel Q8200 + OCZ Reaper PC2-8500 + Asus GTX460 1GB Top..
I already overclock my CPU from 2.3GHz to 3.2GHz..and also overclock My GTX460..
max temperature of my CPU is 60 celcius and max temperature of my GPU is 80 celcius
Yes..I overclock it..
Need I change to default? (My PC slows when use CPU default clock)
CPU = Intel Q8200 2.3GHz overclock to 3.2GHz
