Bacon
I've been pretty unhappy with my computer for some time and its about time I do something about it. My budget is around 1000-1300. I'm going to be switching from AMD to Intel and since its my first time doing an Intel build (most likely going to use Nvidia gfx too) I'll be looking for some advice in those areas.
With that said, here is what I've come up with thus far.
****UPDATED****
At a glance:
Links:
XFX Radeon 6950
XFX 650W
G.Skill Ripjaws Series
ASUS Sabertooth P67
Intel Core i5-2500K
****OLD****
At a glance:
Links:
EVGA GTX 580
Corsair HX 750W
Corsair XMS 2x4GB 1600
ASUS Sabertooth P67
Intel Core i7-2600K
I'm guessing the 580s are the flagship for Nvidia, but is EVGA a good manuf?
Also have no idea whether Corsair still makes good PSUs or not. I would assume so, but you know what happens when you assume..
Was looking at the 2500K vs the 2600K, does 2MB of Cache make much of a difference. Enough to justify another $100? The 1GHz is irrelevant as far as I'm concerned, I'll be overclocking anyways.
I got nothing on the motherboard, just looked clean and has good reviews.
Edit: To clarify my needs for this build. I will be doing a fair amount of gaming and virtualizing on this machine. I also am only looking for modular PSUs. I also do not plan on implementing Crossfire or SLI in the future.
Thanks for any help in advance!
****UPDATED****
At a glance:
Links:
XFX Radeon 6950
XFX 650W
ASUS Sabertooth P67
Intel Core i5-2500K
****OLD****
At a glance:
Links:
EVGA GTX 580
Corsair HX 750W
ASUS Sabertooth P67
Intel Core i7-2600K
